Brass fuel Tanks
Brass fuel Tanks
Has anybody out there had one of these apart........Concerning the 'end caps' the bits with "Seagull " embossed on them , are these soldered on to the main body ?
Brass tanks
When the site gets back to running proper check out the FAQ. There are several ways to repair a brass tank. One at least will meet your needs.
Cheers,
Duane
Cheers,
Duane
Brass fuel tanks
I’ve just had one apart for dent removal.The ends are brazed to the tank body and consequently the only way I could remove them was to cut them off with a hacksaw along the line of the original seams.Re-assemble using the method outlined in the FAQ section.
