fuel line connector
fuel line connector
Looking for a fuel line connector to attach to inlet of amal 2 jet carb. For Century fuel pump project. Thanks Phil
- 40TPI
If a kind local soul doesn't step forward with an original fuel line to let you rob a connector then I'd suggest a trip to your local stockist of compressed air and hose fittings with your carb in hand. I am very sure it is a BSP (British Standard Pipe) thread and they are very common in North America. (Unlike BSF and BSW) The petrol tap outlet end of a Seagull fuel pipe is a 1/4 BSP fitting. The AMAL 46N connector is bigger - so maybe 5/16 BSP?
Peter
Peter
fuel line connector
Thanks for the tip, will give it a try. Think its a long shot though can't think what it would be used on here, everything seems to be npt [US national pipe thread]
Fuel pipe connector
If you have a problem , contact me I have a box of end fittings ....
SOS
SOS
fuel line connector
Thanks I was able to get some connectors.
