problems with silver century
3valleys
Post by 3valleys »
Recently bought a silver century was fine at first. then have had a problem it works fine when in neutral but when put into gear it stops does anyone have any idea why this happens.
Vic
Post by Vic »
Stops dead because the gears are seized? Can you still turn it by hand when in gear? Oil in gear box?
Or stalls due to lack of power or revs?
seararer2009
Post by seararer2009 »
Hi, I'm having the same the same problem - did you find a solution?
Regrds, NEil
Waggles
Post by Waggles »
Check out Vics reply above and mine to 'NOOBIE NEEDIN SOME HELP'
