OMG What have I just bought !!!
- Stelios_Rjk
Re: OMG What have I just bought !!!
Correct decision Huggy and I totally understand you. One CP gearbox came to me by chance and now I want to make a complete CP..!
I started on the paint and replaced the gaskets, its all pretty basic, it does have some damage to the skeg and flywheel, but skeg damage looks pretty common for this little motor, also made a replacement bracket for the tiny tiller arm, I may have a try at some ally welding, to repair the flywheel and skeg, but will have to see as the likelihood of getting another is slim.
Looking good Keith, I am waiting for the weather to improve before I start spraying, also waiting for more polishing mops
Kitchen not warm enough. H-A
P.S. Computer fried, last week lost 1TB everything gone, anim, artwork all gone.
This is the cleaned power head, just needs painting.
I had to straighten the air inlet, it was a bit dented.
Nice pre heat air intake, not bad for 1934.
Are you going to turn something up to replace that screw, it's got to look better with something else.
I like that screw...I bet it took longer to find the right "wrong screw" than to have ordered the real thing!
My spare carb has a hand made replacement.
It looks like the aluminium lever was a little fragile.
I might remove the screw and make a new aluminium one when it is running.
I did a little more to my one, just tank to do and decals to make.
And a tiny tiller handle to find.
david doyle
Not a shed find, and not an outboard find but I did just stumble across 50 Johnson engines under a tarp and available for scrap prices. All 5/8ths and 1 hp 4 stroke IronHorses.David needs to get looking in sheds![]()
- Stelios_Rjk
Beautiful engine and nice restoration,
Well done!!
Well done!!
H-A there was a thread on AOMCI by "Nali" from Montreal he is attempting to cast some carb levers, I think they may fit your motor you may want to have a look at that thread.
Thread titled "Cast A-50 parts" on ask a member.
Thanks Philphil wrote:H-A there was a thread on AOMCI by "Nali" from Montreal he is attempting to cast some carb levers, I think they may fit your motor you may want to have a look at that thread.
I will look at that.
