Aussie Curlew
Re: Aussie Curlew
I'm getting close to getting it to run. The ewart taps I have are all threaded at the fuel line connection instead of the push on arrangement of the original on the left. Had some fine gauze but can't locate it, to make a new filter. I'll have to procure some more or pinch one from another tap. No rush, the motor has been idle for a decade or so.
Trouble with these new fangled recoil starters you can't feel the motor through the rope. With the pulley and rope you can become one with the motor.... peace man :!:
Re: Aussie Curlew
What is the correct spark plug? It had a champion RN 4C..... sounds good to go?
Edit: struth... bit exccy
http://www.amazon.co.uk/dp/B004238LMK/? ... lugcros-21
RickUK
Re: Aussie Curlew
Post by RickUK »
Correct plug is/was the RN4C - not sure it is still current, or if you have to use an equiavalent now.
Curious about the lack of fliter in your fuel tap I've just had one of the same age and type out, and it doesn't look as if the recess is intended to be a register for a filter, though I find it difficult to imagine Seagull would have left one out
Re: Aussie Curlew
That's interesting Rick. Couldn't find an old filter lazing about in the tank either. I've added a bit more plastic... :oops:
If I was keen I would be happy to kick her over now but a tad wet over here.
Re: Aussie Curlew
Woo Hoo! Got the old girl running. Runs fine out of water but when in water only runs long enough for water to pump into water jacket and then stalls rather quickly. Very high compression for the first revolution on restart and starts again which, I surmise, is due to water entering the firing chamber. Considering the corrosive state of the water cooled head, I wouldn't be surprised if replacing head and gasket doesn't rectify this problem.
Idles well and is very responsive to twist throttle. Revs very fast when lifting tiller arm. Stop switch operates. Gearbox and clutch lever operating perfectly as well. No fuel drips anywhere :shock: . No water from telltale but again new head should fix this, if not some clearing of jacket...... :D
Re: Aussie Curlew
Nice to hear that it goes Huggy!
Now, rip the head off so we can see where the internal crack is etc.
Champion RN4c is available still.
Re: Aussie Curlew
Okidoke. Will do!!
I'm running a NGK BR7ES which is comparable.
Re: Aussie Curlew
So,,,,,,,,Any News?
Re: Aussie Curlew
Not yet. Concentrating on getting my hippie van through MOT. And women are distracting me......
Re: Aussie Curlew
Tinky the hippy van passed her tests!
But Curlew is all choked up... :|
Head disintegrated on removal.
Will see if block is salvable.
Re: Aussie Curlew
Ok, anyone got a photo of cleared water jacket? Trying to work out what is crap and what is part of the web. Cleaning up ok though.
Two sides and bottom galleries are cleaning up but the top one doesn't seem to be as straight forward.
Re: Aussie Curlew
Exhaust tube is being a real muther to get off. Always have trouble with these. Heat and WD40 I guess and some raw Aussie expletives. Surprisingly the allen key holding the pipe in posi removed easily. Motor and leg separated easily enough too. Apparently the water tube can seize in the water pump housing, but not this time. (thanks Ch/UK)
Re: Aussie Curlew
Congrats Hippy Van!
This looks like a work in progress indeed.
Thanks for the pics!
Daryl
Re: Aussie Curlew
Post by Daryl »
Beware of the Women distraction, you may loose Focus.
Re: Aussie Curlew
Must be getting old, I'm enjoying this more than consorting with wanton Ginnies..ha ha
Exhaust..... strike me lucky it is in good nick. Slight corrosion where the rubber O ring sat to stop water inlet pipe from rattling on exhaust. Will need to make new exhaust gasket or acquire one. I'm assuming an exhaust gasket will require different material to the norm?
John should be back soon and order I shall.
I'm beginning to think this motor hasn't had a lot of use but has been exposed to the elements for a while. So far every fastener has released easily..... how unseagull is that!
