Page 2 of 7
Re: An FVP in USA
Posted: Sat Dec 31, 2016 12:15 am
by tambikeboy
tambikeboy wrote:water bug wrote:Thank you all for the comments. I will take off the notes and see what I can do to make corrections. Please someone post a picture of the two piece (hens teeth??) thrust block. and one of the correct earlier tank cap and one of the earlier style high tension wire needed. . I may have a threaded water pump housing but as said that would necessitate a threaded torque tube as well. SO I have some more work to do. I am VERY glad that collectors in the UK are being very particular with originality. A few years ago it seemed to me that any mix and match of bits would do, No longer. Thank you for the assistance. WB
Hope this helps I'm away from home untill next week might have a threaded drive tube kicking around will post more detailed pics when home note plug cap comes in two parts. .....
Re: An FVP in USA
Posted: Sat Dec 31, 2016 12:19 am
by tambikeboy
Your tank cap looks fine to me......
Re: An FVP in USA
Posted: Sat Dec 31, 2016 12:34 am
Like this.
The thrust block I'm pretty sure is made from bakelite in two half's, I can give you the spec of them.
I cannot see why you can't make them out of a hard black plastic.
Re: An FVP in USA
Posted: Sat Dec 31, 2016 1:25 am
Can someone post a pic of the cotton wheel correct thrust block please.
https://www.youtube.com/watch?v=ugTLm_PmCzc
Re: An FVP in USA
Posted: Sat Dec 31, 2016 7:29 am
Do not stay up too late tonight Huggy. All the best for '17 outboards.
BnC[/color][/b]
Re: An FVP in USA
Posted: Sat Dec 31, 2016 10:30 am
Ahh yes very good. Thanks. A job for Keith and 3D printer. I though they were metal for some reason. Mine is timber ha ha.
Re: An FVP in USA
Posted: Sat Dec 31, 2016 2:52 pm
by water bug
Collector/inspector : Please tell me the radius of that cotton spool thrust block. Are those two plastic pieces all that are needed? I will have to make a couple. Does my FV 2089 also need one? ( little fourth minus) Throttle cable routing FVP : Should the cable go round and under the back of the flywheel? or or forward outside the flywheel? Sparking plug cover, two piece : that brown plastic sleeve looks to be hard to find. Does any one have them or one? Are they phenolic impregnated paper? HAPPY NEW YEAR WB
Re: An FVP in USA
Posted: Sat Dec 31, 2016 3:40 pm
by tambikeboy
Fvp throttle cable set up...as for the 2 piece plug cap there like hens teeth Jeremy is the man to tell you what it's made of .....
Re: An FVP in USA
Posted: Sat Dec 31, 2016 5:12 pm
I don't have that cap, but it looks to be a Champion cap and a tufnol skirt.
Or just ask Jeremy.
Re: An FVP in USA
Posted: Sat Dec 31, 2016 5:22 pm
by tambikeboy
Yes right again keith champion plug cap.....
Re: An FVP in USA
Posted: Sat Dec 31, 2016 7:53 pm
by water bug
Thank you ALL. How do I ask Jeremy questions? Here is my FV cable routing. It seems that is OK. WB
Re: An FVP in USA
Posted: Sat Dec 31, 2016 8:46 pm
Hi Art
Go into BOARD INDEX direct from here. (top left of the screen)
Look for PRIVATE MESSAGE (top right corner of the screen)
Then look for the user name under G (Gannet)
Then ADD or SELECT
Then type your PM to Jeremy.
Once you've done 1 message, it'll be easier the next time around.
Good luck
Re: An FVP in USA
Posted: Sun Jan 01, 2017 12:20 am
water bug wrote:Thank you ALL. How do I ask Jeremy questions? Here is my FV cable routing. It seems that is OK. WB DSCN9129s.JPG
The cable is too long. FVs had one very much shorter.
You have a longer tiller........try moving the throttle forward along it. It will fit better.
Re: An FVP in USA
Posted: Sun Jan 01, 2017 12:57 am
NTS or NTFS that is the question.
[/b][/color]
Re: An FVP in USA
Posted: Sun Jan 01, 2017 3:20 pm
by water bug
Here are a few pictures of most of my Seagull flock. WB
