" FP 255 ICI " All I can make out from the engine code is that it is a forty plus standard shaft 67-79.
255th made? surely not. From the ID page, I thought they didn't use "I"'s in the codes?? I've got two, whoohoo!
This is seagull number two now, got a featherweight as well.
A lot of the fixings are pretty corroded , needs a new tank and fuel line but it turns over fine and has a spark. can't be bad can it.
