Boxed and without hardly a blemish, this is a very rare opportunity to obtain an unmarked tank.
The 5 pint capacity 'longe range' tank was fitted to many of the Silver centuries before that horrible 8 pint steel tank.
The fuel outlet can easily be moved from one side to the other if needed, by simply undoing the straps and turning the tank end for end, thus it will suit any Seagull with Amal or Villiers Carb. From Featherweight, if you must, through FP up the Silver Century or model 90. Fits to head same as the normal tank, using the Ali carrier, with chrome straps all included.
£120.00
01621 778859 or via the website e-mail.
SOS
