Next generation of Seagull users
When your daughters friend pops round and says " I want to make a boat" what do send him home with.
Lets hope he can get it going with a bit of help :)
fleetingcontact
Re: Next generation of Seagull users
Post by fleetingcontact »
That link did not work for me.
fleetingcontact
Hmm. Try this by copy & pasting it.
http://www.mojaladja.com/upload/McGraw- ... (2007).pdf
fleetingcontact
fleetingcontact
Cant seem to post it as it appears...seems the .pdf suffix is messing it up somehow.
Either google Ultrasimpleboatbuilding.pdf or type out the link manually:
Screen Shot 02-10-19 at 04.54 PM.JPG (9.78 KiB) Viewed 3068 times
OK will try that thanks
fleetingcontact
I also have a few designs to work from not in that book (which is great) but to be fair there is tons of free stuff on the web.
fleetingcontact
I think this one is the bee's knees but perhaps less useful for users of outboards...also involves paying for a kit but the plans can be bought separately...
and here's a page from a brochure where the real marine plywood (not to be confused with the sub-standard stuff in most timber merchants) is still sold.
This lot will also cut a sheet of ply to any shape you like.
african imp
Post by african imp »
Horsley-Anarak wrote:When your daughters friend pops round and says " I want to make a boat" what do send him home with.
If he wants a boat kit he can try at this address ? http://www.ckdboats.com
Various grades of the correct marine pywood to BS 1088 are supplied, plus other acceptable options as well
Thanks for the link, he is only 16 with not much money. I think DIY store ply and polyester resin will be the way forward.
He can copy one of the boats I have designed, If he likes boat building then better ply and epoxy will be the way to go.
This one is surviving well, cheap ply and polyester.
Nice breasthook and gunwhale HA.
fleetingcontact
BS1088 is a standard that refers only to the methods of construction, not the species of timber used. The required standard is surprisingly low and there a a great deal of variance between suppliers. Few offer anything like the standard that existed before BS...
Cheap has its virtues; it would be very easy to spend a lot on the more desirable qualities to the point that before very long you might wish you had bought something and saved all the grief too (unless the grief is the fun part).
https://www.porta-bote.com
