Early SD Bits Needed
Post your wanted adds here
seagull101
Post by seagull101 »
After a bronze non inscript clutch lever and a brass non chrome throttle lever.
Need them for my new SD575.
PM me what you have.
Jacob
Re: Early SD Bits Needed
I wire brushed off the nickel on a fuel cap so l assume you can do the same to the early amal throttle lever. SD 571 is in Germany. I don't have the details for 575 do I?
Edit: that's the half one 8)
seagull101
Yeah could do that but would rather leave a chrome one for someone who needs a chrome one. I assume it is a non chrome one i need for it???
Yep thats the one, ill get you full details once its built up, probabably by new years.
Jacob
Good O. Of the 37 levers documented 34 are brass so l think that is a safe conclusion. I'll publish the updated registry soon.
Couple of other things. Yours should have gearbox with nipples on starboard side and the crankcase on the tiller side should have a number... B3xxx. I wouldn't be too worried about the nipple orientation.
