On a serious note. Being a cat hull how does it turn with some power on the back? Wouldn't the leading edge (outer hull) dig in and start to flip? This could be a bit of an animal to control. Be good in a chop though. Actually it would be stable at anchor overnight. Will have a look tomorrow to see what I bought. I think I'm going to have fun with this.
Hugz wrote:On a serious note. Being a cat hull how does it turn with some power on the back? Wouldn't the leading edge (outer hull) dig in and start to flip? This could be a bit of an animal to control. Be good in a chop though. Actually it would be stable at anchor overnight. Will have a look tomorrow to see what I bought. I think I'm going to have fun with this.
The joys of not having a missus or three.
G'day Hugz,
Cats act/drive in the same way as cars. If you can drive a car, you can drive a cat. Very stable at rest, but the slap under the hull can drive you nuts.
Being an older boat, I suggest you check the floors and transom for rot mate. To check the floors, wear firm shoes and walk along on your heels. If you see/feel any movement, the floors will need to be replaced. Best way to check the transom is with outboard on. As there's isn't one on this boat, tap along the transom with hammer and listen for the noise. If it's not consistent, there is a high chance of rot.
Why wouldn't an SD be good enough to power Hugo's boat? It won't be fast i grant you, but definitely maneuverable. I think you underestimate what a good 102cc seagull is actually capable of. It's not all about going fast either.
I have a similarly large and heavy boat, although a single hull and 17ft in length, and an SD works just fine on there so why not on a cat hull?
or even a trimaran come to think of it https://www.youtube.com/watch?v=-e-q0BJUjxI
Too much boat do you think? Not to me, just shows how versatile a seagull REALLY is.
Obviously with no tide or wind a gull will push just about anything, but against a tide a very different story.
We haven't asked what Hugo intends to do with his latest purchase yet. Does he want to go fast or does he want to potter about? Where is Hugo going to use this boat, calm inland waters or open sea?
