Anzani Unitwin 10hp
Anzani Unitwin 10hp
Ozzmotorz
Re: Anzani Unitwin 10hp
Post by Ozzmotorz »
Looks to be in nice condition.
Probably a good deal, for a collector.
Yep, I'd say less than 1 pound is a good deal.
Arn't those ones hernia material?
Hugz wrote:Arn't those ones hernia material?
Yes indeed they are Hugo.
This a ten as per the exhaust diameter into upper gearbox plate noting the casting..
I suggest that no one believes a badge. Badge engineering turning a 10 into a 15........see it all the time.
This is something someone local should investigate aye!
Indeed a 10.
And I thought it was easier than that, the 15 had a three blade prop and the 10 had a two.
There are in fact many small but significant differences. Not too difficult to identify when seeing them in isolation, but when side by side it all becomes apparent.
10hp 242 cc vs 15hp 322 cc. 15hp has a larger diameter bore, is substantially heavier and spins a larger diameter 3 bladed prop.
Of course......
