TC 102 prop ?
Re: TC 102 prop ?
Does that make you two, Jaffas?
You will meet more people on Friday afternoon.
mjling
Re: TC 102 prop ?
Post by mjling »
Hi Charles,
Its just that I don't fancy driving down from Auckland in all the holiday traffic on Good Friday, Saturday morning should be a lot easier even if it will be an early start.
Marcus
Re: TC 102 prop ?
Most will be too busy to talk on Saturday morning, you could walk to Nudges in an hour, from what I read in last Easters results, he's quick!
mjling
Re: TC 102 prop ?
Post by mjling »
OK here's some more photos, I have partially stripped it down to assess what needs replacing.
Here's some photos of the bracket
mjling
Re: TC 102 prop ?
Post by mjling »
Seems to be a limit on the number of photos in each post
The clutch lever has been repaired at some time
The tank body is pretty good but the ends need some attention
Re: TC 102 prop ?
Let me try and elaborate a bit with props.
Seems there might be some confusion with early and later style props and what we call them, so here goes.
There's plenty of others in all different shapes and sizes, early - mid production and on into the later years.
This is just a snippet of what was produced over the years.
later style "weedfree" types and a 5 bladed "hydrofan".
top centre is a 4 bladed &quot;hydrofan&quot; for a 102.<br />A &quot;cloverleaf&quot; will look very similar to the prop at top right even though this is for a century motor. 102 props have a slightly smaller hub than their cousins.
top centre is a 4 bladed "hydrofan" for a 102.
A "cloverleaf" will look very similar to the prop at top right even though this is for a century motor. 102 props have a slightly smaller hub than their cousins.
top left is a Bargepusher 3 blade, top right is a 3 blade Meatcleaver. Note the different shape of the blades with a straight trailing edge and curved leading edge.
Re: TC 102 prop ?
Your 3 bladed "Meatcleaver" is what we've always called a 3 bladed cloverleaf, it should have 102 on the hub.
While the straight trailing edge might well slightly resemble a cleaver prop
it seems to been a high thrust version of the 4 bladed 102 cloverleaf for use with heavier hull shapes, with no surface piercing ability.
I think you'll find as your SD researches start to bear fruit that your 3 bladed "Bargepusher" is a Wartime HSD prop, you will note if you look closely that it's cast from Birmabrite.
Re: TC 102 prop ?
That's brilliant, fabulous, wicked, astounding, legendary, apocryphal, wonderful, great, groovy, excellent, fantastic, marvellous, superb, splendid, extraordinary, incredible, phenomenal, astounding, unbelievable, spectacular and sensational, you posted a picture Charles.
Plus Ironic. :lol: :lol: :lol:
Ring ring.
Re: TC 102 prop ?
Perhaps he had wind? :lol: :lol:
Re: TC 102 prop ?
I'd also suggest just to be a little pedantic (Or accurate) that a four blade 102 prop is not a hydrofan. The hydro fan prop is 5 bladed as introduced on the century.
Re: TC 102 prop ?
Sorry Oyster the "Hydrofan" bit refers to the blade shape, long thin narrow corded blade, originally sold as a low drag improved performance prop offering a low cost upgrade to all of the pre hydrofan props, I think a 5% improvement was promised.
A performance upgrade for all the then current models from 40- to the century+ not including the 102+.
Re: TC 102 prop ?
Interesting, I thought the term was used to describe the 5 blade prop. Looking at the olde leaflets on the SOS webpages I see that a 40+ was offered with a 4 blade hydrofan prop. I stand corrected headmaster :P
Re: TC 102 prop ?
Not a problem.
As here at S-O-S we have taken up the role as the primary factual reference site for Seagull data, & the moderators have fallen into the task of keeping it as accurate as possible, hence us acting as grumpy schoolmasters!
Re: TC 102 prop ?
Yah. I always thought the hydrofan was for the 11 and 13 inche five bladers. Thay look most un-nautical and upset my sensibilities.....
Re: TC 102 prop ?
Chas. i think if you try and remember from a couple of years back that YOU now have that 3 bladed bargepusher prop, although my wartime research hasn't revealed anything at all yet about HSD's or what sort of prop they wore. I rejected this prop from my "bargepusher" purely because the hub was far too small for a PLUS sized gearbox. It just didn't look right to me. Up till now i've only ever heard a rumour that 1 HSD survives somewhere, hopefully there are more. Apart from maybe 2 other earlyish post war "bargies" i've seen over the last 6 years or so, most early 102 bargepushers seem to have a 4 bladed cloverleaf unless anyone can confirm either way.
I have my doubts with these 3 bladed versions though. There's far too few genuine unmolested 102's these days to be able to arrive at any firm decisions as to what's genuinely original to that particular motor, or what is a later addition or "upgrade".
Having said that, doors are being opened all the time on dusty sheds and garages all over the country so who knows what will be discovered. We sit and we wait.
Getting back to topic:
As far as we can tell (for now any way) a typical prop for a TC would have been a 4 bladed "hydrofan". The vast majority seem to be so.
I'm a little concerned however looking at the pics provided that the gearbox for this 1958 102 has holes instead of slots for the water inlet.
I can't help thinking that at some point in this motors life that the entire gearbox/prop combo has been swapped from an older motor.
It makes sense going by the "bowtie" prop, but i'd like to see some better pics of the gearbox before i make up my mind on this :P
Unless the owner is worried about originality, then i see nothing wrong with the parts so far. Repairs are one of those things that a motor picks up along the way. It's easily put right. Just ask...
