If I have any incorrect or you have more to add please let me know and I can fix it.
Seagull Threads
Flywheel nut 7/16 x 18 BSF
Villiers coil base lug studs 2 BA. Brass nuts
Villiers carb retaining clamp 1/4 x 28 unf
Villiers carb inlet 1 3/16-28 Brass (1 3/16-28 UNS is close and will work)
Fuel tank tap lower thread 7/16 x 19 55°gas thread
Fuel tank tap upper thread 1/8 x 27 60° nps parallel pipe thread (can someone please check)
Fuel cap 1-1/4 7 TPI 55deg
Amal 400 float bowl 1/4 BSP,
Spark plug A6 or D16 M18 x 1.5mm pitch 1” spanner(for the D16)
Gearbox pinch bolt 5/16 BSF
Cylinder head bolts 5/16 BSF
102 Tiller wing nut 3/8 BSF
416 carb cowl drill 30.7mm tap 24 TPI 60° (1 1/4-24 Brass) UNS is close and will work
Amal 46N storm cowl 24 TPI 60°x 0.812"
exhaust tube to the cylinder block is 2 BA.
transom bracket thumb screws are 7/16 BSW.
Early 102 water pump housing to gearbox fastener 5/16" BSF
Flywheel woodruff key Imperial 5/8'' by 5/32".
securing bolt for a WIPAC/Villiers ignition base to crankcase 5/16" brass (this may be 5/16 Cycle thread (26 tpi, 60 degrees)) Needs to be checked
gear box filler cap 3/4" x 12 TPI That makes it 3/4" BSF
If bolt is close to 8mm then it will 5/16 BSF
If bolt is close to 6mm then it will 1/4 BSF
TORQUE SETTINGS FOR BRITISH SEAGULLS
5/16" CYLINDER HEAD BOLTS 18FT.LBS
5/16" CYLINDER BASE BOLTS 18FT.LBS
1/4" CYLINDER BASE NUTS 9FT.LBS
1/4" CRANKCASE BOLTS 9FT.LBS
9/16" DOME NUT FOR FLYWHEEL 24FT.LBS
BEVEL PINION DRIVE SLEEVE 20FT.LBS
Distance between bracket and water line:
SJM=355 mm, SJP=410-425 mm, SJPL=555-565 mm, LLS=410-425 mm, LLSL=555-565 mm, TC & THC=410-425 mm, TCL & THCL=555-565 mm.
