fvp7089
Re: fvp7089
No in the world cover Tam
None of my fvp,s have lettered covers ????? does that make them wrong i know for sure that one is completely original....china
Re: fvp7089
The lettered cover came along during the production run, but earlier ones were blank. I think Jeremy has this change point tracked down fairly close. The stuff he has on the main SOS site might well tell you.
Re: fvp7089
From the data that I have collected,the flywheel cover almost certainly was being fitted with 'in the world' by serial number 15000. It might have started by S/No 14000 or possibly by S/No 13000. Evidence suggests that all engines prior to approx 13000 would have had plain covers.
That means that all FVPs would have had plain covers.
I am shortly going to reissue my updated sheets. There are 11 pages of indispensable (I think so!) information. Is it possible that if I convert them to pdf form, that i can load them onto a post?
Re: fvp7089
NICE ONE JEREMY KEEP UP THE GOOD WORK china
Re: fvp7089
No you can't post PDF's on the forum. Make it a JPG
Re: fvp7089
I've found one of the quickest ways of converting a word page is to take a screenshot, then crop the resultant photo. Only downside is you have to do it a page at a time.
Re: fvp7089
I have PDF software that makes PDF's from what ever format or splits PDF's into original pages, pretty basic stuff.
Re: fvp7089
Yes, but it needs onto be a jpg to post it here.
Re: fvp7089
Or you could just add a link to down load it, Its simple if you own a website or four.
Not that it matters to me either way, but I think the quality of any text in a Jpg picture format is pretty much unreadable, plus it will always be stuck in that low quality format, as it will be in picture format, not a text format.
Re: fvp7089
All dings repaired ready for paint shop anyone tried powder coating yet...
Re: fvp7089
What have i done is it possible that the top crankcase bush has moved when i removed the flywheel after giving it the usual whack with the hammer bottom half is fine i gave the crank shaft a few taps with a rubber hammer and its only making it tighter over to the experts
Re: fvp7089
I read this, So now I have got my breath back.
Tam most if not all little models have a silly amount of end float, a good quarter inch.......
Re: fvp7089
I think i might have been misleading the crankcase s are not coming together get my drift china
Re: fvp7089
Aha, What have you changed ?
