I could not see that it would be hard to get them off, and as I thought with a bit of heat from the Propane torch off it popped.
What you need to do is mount the tank vertically (having degassed tank, get this bit wrong and you may create a good bang) and apply heat to the bottom end. This will let all of the end heat up at the same time.
When you see a thin line of molten solder around the joint, apply a little bit of downwards pressure at the joint to the end cap using a screwdriver.
If you have all of the end hot enough, it will just fall off.
I had a bucket of water underneath to quench and anneal the end cap.
The whole process took only a few minutes, have removed all of dents and it is now ready to silver solder back together again.
Can post a picture of tank in bits if people want to see it.
Thanks
OK
