FV 2844 Needs A gearbox Case
Yep, a case only at the minimum......all inside is cool for a refit.
				tambikerboy
Re: FV 2844 Needs A gearbox Case
Is that the same as a little 40 ??
With 2 holes on the water inlet.
Have you tried Jeremy? (not sure if he's away boating this weekend)
Sorry, I don't have any FV parts left now.
Thanks Guys.
Looks like I have to get some creative juices flowing using a slot water inlet box as a starting point.............6 beers mulling what to do.........
The original box is really good internally................no skeg.
So change a slot box with a skeg or add a skeg to the holy two .............that is the question.
I have replied to your PM Tam
Out with the welder then!
Might be a good way to go until a good replacement turns up.
Back from boating now Jon.
Bruce, I am sure that you are aware that the early Forty Minus (SJM) had the polished 2 hole gearbox housing. I do not know the change over point. Technically I suspect that the slotted version is better in respect of being less likely to have the inlet blocked up, especially by sea weed. This is often happening to my FVs on the estuary in South Devon. But I like originality, otherwise whats the point?
Anyway, getting to the point, I haven't got a spare housing. With a couple I need to do minor weld repairs, but do not have the equipment or skill for that.
Hi all.....just a jog.
Welder?
Turn a slotted box into something that looks older. (i won't tell anyone, especially not Jeremy)
Shhh. Wink
Shhh. Wink
FV boxes are about, but you might have to buy a whole engine.. Still the littles forties are still fairly cheap.
Looks like Tam has come up trumps in that box and a High Amal bowl has been sent to me.
Yes indeed he has!
The gearbox is perfect and Tam also found me a High Amal bowl.
Arrived today and I know that I am the only lad down under with a perfect as new http://www.homebargains.co.uk 100% recycled plastic shopping bag.
BnC[/color]
 BnC[/color]
There's always a bargain to be had in SCOTLAND   where men are men and sheep are nervous
   anyhow they push back better....
 anyhow they push back better....Roll me up and smoke me when I die
