Any idea?
speedcase
Any idea?
Post by speedcase »
Hello
I have a century plus it starts immediately but then stops, restart again ok, but stops again, etc. allready changed sparkplug.
Every tip welcome.
charlesp
Post by charlesp »
Strong suspicion of fuel starvation here.
First thing to check is that the filters in the tank and the carb are scrupulously clean, there's no gunk in the tank or fuel line, and that the jets are clear.
timberman2004
Post by timberman2004 »
have to agree with Charles ..
much trial and loads of error, wringing of hands and rending of garments, but my experience has led me down the path with any new acquisition, before even trying to start it ...
1, tank off, tap out, and scour out the inside of the tank, rinse scrupulously
2, flush and blow out all filters and fuel lines
3, carb dismantled as much as necessary and surgically clean
if you've got a spark, she'll start !
slight possibility in this case though of a leaking head gasket ?
speedcase
Post by speedcase »
Indeed, tapped the old gas out of the tank, cleaned carb, filled up with new gas; 1 pull perfect start.
Thanks for the reactions.
