Driveshafts...
AusOB_Collector
Driveshafts...
Post by AusOB_Collector »
Hi All
As mentioned in my thread regarding my AD, when I purchased it, the only thing missing was the driveshaft. :roll:
I was wandering if anyone could provide a length and inside measurements square for a standard length AD 102 driveshaft?
Even just the length would be greatly beneficial.
BP
Member SOS, AOMCI,
Re: Driveshafts...
This is not an essential part Boyd. Just place the outboard in fast flowing water and the prop will turn regardless :lol:
Re: Driveshafts...
This is off a 102 TD (I think)
Can someone advise if this is the same configuration as an AD?
And which part comes off next? I always thought the square shaft goes through the rotor but appears to reduce to a circular rod. KEH???
Re: Driveshafts...
AusOB_Collector wrote:I was wandering if anyone could provide a length and inside measurements square for a standard length AD 102 driveshaft?
Wouldn't the internal be the same measurement as the square drive at the bottom of your crankshaft?
Re: Driveshafts...
As it's already apart, I'll take some photos of the drives and input shafts of my AD102 and post them up over the weekend.
AusOB_Collector
Re: Driveshafts...
yes the internal measurements will be the same either end; don't know why I didn't think of that. :shock: :roll:
Would you be so kind as to measuring the length of the driveshaft so I can cut one to size please?
Thanks and Cheers
BP
Member SOS, AOMCI,
Re: Driveshafts...
When cut to length there will be some grinding inside.
Modern availability of square section tube in AU will require that.
Easy.
Re: Driveshafts...
Length of the square section is 18 7/16"
I note the square head waterpump and bevel drive are somewhat different to the 102's.
Still would like to see some pics of box disassembled.
Re: Driveshafts...
The drive shaft was cyanide hardened at both ends to prevent twisting & locking in place happening.
We haven't be able to source any square section tube of a suitable size here in the UK, let us know if you find any.
Though British Seagull or John might be able to lay their hands on a longer one that you could cut to size, if the ends of the one you find have been hardened, you'll have to cut with an angle grinder as a hacksaw will really struggle.
Your quite lucky in having your pump impeller on the pinion shaft as it means you can use 2 x 3 inch sections of drive shaft welded to a suitable length of round bar, quite a few like that over here, just make sure it's perfectly straight!
Re: Driveshafts...
"Your quite lucky in having your pump impeller on the pinion shaft as it means you can use 2 x 3 inch sections of drive shaft welded to a suitable length of round bar, quite a few like that over here, just make sure it's perfectly straight!"
That as well BP.
Shearwater
Re: Driveshafts...
Post by Shearwater »
Charles uk wrote:The drive shaft was cyanide hardened at both ends to prevent twisting & locking in place happening.
Are all Seagull drive shafts hardened at both ends?
Re: Driveshafts...
It doesn't seem like all the early ones were, but after circa 1970 all the 102 cc models seem to have been, but don't take this as a researched fact, I only know about the ones I've tried shorten.
To be sure try the end with a hacksaw, if it's a job to scratch it, it's been hardened!
It seems this was part of Seagull's continual improvement program, when a problem occurs, fix it, the first step in this with the drive shafts, was why they increased the drive shaft wall thickness in the late 40's.
