How hard is it and what is the procedure to remove:
- the front end cap bush, heat?
-and the bevel pinion?
on a FPCl 667CC8
I have a post about the gearbox in the 'General' section. i should've put it here but once it was posted I couldn't figure out how to move it
front end cap bush and bevel pinion removal?
Go for the juggler!
Go for the juggler!
Re: front end cap bush and bevel pinion removal?
Both a bit tricky..
For the pinion - lots of heat and use of a drift to move the old pinion assembly upwards and out. You will need a very heavy duty torch such as the type roofers use to melt pitch..or degrease and put in the oven when the other half is out..of course all the paint will burn off too. I have a 102 gearbox that needs a new pinion, I was thinking if some sort of clamp tool could be made to ease the old one out?
End cap - years of neglect will see this bush well corroded in place. I would probably cut one or two slots in the bush bore and implode the bush in situ then pull it out in pieces. I'm not sure if new ones are available but I'm sure a friendly lathe owner would knock one out fairly quickly.
The thread below might be useful. The search tool on this forum is actually quite good.
viewtopic.php?f=5&t=2398&p=15829&hilit= ... val#p15829
Thanks
I'm checking out options in case shipping gets too costly on the whole unit, the Canadian dollar is in the tank right now,basically 1/2 a British pound
I found that thread just after posting mine, I don't have a replacement bevel pinion but I do have a bush in a century end cap that would do the trick. Mine doesn't look corroded in . the cap's is in good shape, it's just been ground by the shaft into an oval hole.. The century bush looks perfect but the cap is definitely on it's very last legs.
Hopefully I can afford the whole unit!
Go for the juggler!
Go for the juggler!
Do you need a replacement gearbox? FPC is that correct?
I have a couple spare which might yield some usefull parts, broken skegs though but all innards appear serviceable. Good end caps too.
Drop me a pm if interested
