ebay find
Re: ebay find
It's a "bitsa". already asked the seller what is it?
Silver century crank cases, crank/rod/piston inside an old 102 block. Wipac points magneto,standard (ish) sort of tank and not much else to it. Nothing special really.
A bit over the top for what it is in my view.
Re: ebay find
hi Jon shows my lack of gull knowledge thought i had spotted a good deal on the 102.
never mind back to seagull history
thanks garry
the animals are winding me up
Re: ebay find
Keep asking questions and stuff Garry.
You may note that the flywheel stands off the ignition plate.........with good reasons as above.
You can also see that the crankcase halves are not the same.........one is shiny the other is just wrong.
Pitty whoever buys it expecting pull rope action.
Not long and you will get your "Eye In"....Aye.
Re: ebay find
I was a "newbie" once.
As Bruce has pointed out, once you get your eye in, things get much easier.
Takes a while to spot a "good'un" from a rotter.
Re: ebay find
thank you for your support and encouragement guys. kind regards garry.
