instructions or Amal Carb
flyguy
Re: instructions or Amal Carb
Post by flyguy »
Finishing touches before it gets to work.
I fitted the replacement Carb (thanks Tam)
fitted new filter, checked the gear oil, checked plug gap and made sure I have the right size spanners for all the nuts.
I have a special hose coming to back flush as I see some mud in the water pipe
only other thing I wonder about is petrol/oil ratio, I know it is a 25/1 mix but would I be better with increasing oil to 20/1
its going to have a good few trips, nothing more than a couple of miles at a time.
flyguy
Post by flyguy »
With the replacement Carb from Tam fitted I set it up this morning, backflushed the waterway with one of these
and got soaked to the skin :shock:
very little dirt came out so guess its clean,
filled the bin,
Then pulled the cord and it started right away, I ran it until the fuel tank was empty without a problem, a good 30 minutes on half power
so next time I start it I will be using it on a boat in Caithness
Bye Bye rowing, Bye Bye bad back, Hello the far end of the Loch
thanks everyone for all the help and advice
My next project is I am going to buy a non runner and over the Winter strip it down and rebuild, having looked through this forum I think most things are covered in detail but I am sure I will have lots of questions.
thanks
flyguy
Post by flyguy »
The Seagull is running well, couple of times it stopped but started again, took us up and down a few lochs
Photos to follow
Excellent! Good to see you enjoying the engine 8)
flyguy
Post by flyguy »
Thanks for all the help and advice, the motor did everything I needed, I put it on a boat on Loch Watten, the other anglers were using Yamaha, Suzuki and other exotic makes, I noticed a few funny looks and a smile or 2, we rowed out of boat bay, I pulled the cord and it started first time, gently away then increased the revs and we powered up the loch,
it took me up the North bank where I got this beauty
the next day saw us fishing Badenloch near Kinbrace and here it is ready to roar
A funny thing happened on Badenloch, about half a mile up the loch the Seagull stopped, right out in the middle where no fish are usually feeding, my pal cast his fly and instantly a fish, we hooked trout after trout for an hour, I then pulled the rope and again it fired up
$od Yamaha when Seagulls have built in fish finders :P
flyguy
Post by flyguy »
bikerboyfife
Post by bikerboyfife »
Help :shock: :shock: :shock: might have to stay a little longer down the river tonight will tie a plank to my erse incase I fall in :shock:
I love the video, glad you got it running well.
flyguy
Post by flyguy »
Tam, those are Gates waders btw :lol: Dumfries
H-A without your help and the help of everyone on here I would have still been rowing.
its back out on the water in just over a week, Lairg trout need to be worried
