Villiers coil replacement thoughts..
thepetrolist
Post by thepetrolist »
I have a non-functioning Villiers coil in my 1960 Century LLS. I know, I know, the obvious thing to do is to order a new one online. But let's step aside from that thought for a minute.
Is there any other, more common coil, that is known to work in these engines with only the coil being different? Is there any way to install another coil and make it work with the existing setup?
Someday I will get me a new Villiers coil but right now I'm too cheap, so :lol:
I would like to fire the engine up and the only real thing stopping me is the coil..therefore, I would love to try some other solution.
So please guys, give me your best ideas and lets leave those obvious "buy a villiers coil"- comments unsaid.
This can become quite an interesting thread :-)
British Seagull: '52 AC, ’59 LLS, '60 LLS, '67 WPL, '77 WSPC
British Anzani Minor red label
Johnson Seahorse HD-26 1951, JW16 & JW17, 1968 9.5
Evinrude Sportwin 1963, Fisherman 1975, Yachtwin 1964, Sportwin 3.3 1939
Stelios_Rjk
Re: Villiers coil replacement thoughts..
Post by Stelios_Rjk »
geofflena
Post by geofflena »
Just to get a motor running for your own pleasure - and non critical use - then the shorter villiers type ( chinese ? ) coils at £20 squid are a good bet. ( Green spark co ltd )
OK - the body is shorter - the grub screws are only 'just' going to grip - but there is a good solid bar in that lug anyways. You only have to mod the HT dimple with a small solder pad.
You won't sort anything cheaper seems to me - but I have no idea what they are like in terms of reliabilty.
Who makes the 'proper' villiers coils ?
