While I'm at it...
While I'm at it...
...black fingernails and all from the Seagull, it's probably a good time to address that Riptide Boatman I've got sitting in the shed. Can anyone give me a lead on the technical details? Spark plug, fuel mix, lubricating grease, what the ignition advance lever does and should be set at for starting, all that sort of thing.
Re: While I'm at it...
Does it look anything like the motor in my avatar? Collector Inspector (Bruce) has the gen on those. I'm after a Riptide carry handle if anyone is parting.
Lots of interesting motors in your part of the world.
The oz national Seagull gathering is on at Goolwa SA, 19/20 Feb 2015 if you are the traveling type.
No, yellow tank and just the single cylinder. The carry handle is an integral part of the casting on mine.
Perhaps i am in the wrong forum here too. I might go across to that other one with my Riptide enquiries.
