The Gold Cheetah outboard was manufactured by Boundy Manufacturing Co. Pty. Ltd. Springvale Victoria from approx 1954 through to 1960. Boundy also manufactured the Lawn Patrol and the Lawn Cub movers. All shared the same 3.6hp engine, was was quite unique. The engine did not have a traditional style flywheel/magneto atop, rather it had magnets attached to the crank which passed along side an ignition box comprising coil, points, condensor and points all mounted on the front of the crank case. The ignition cover was made of a plastic material and easily damaged. Unfortunately finding replacements almost 60 years on is not so easy!
That said, a bit of good luck comes our way I guess every once in a while. Over the weekend I stumbled across a Lawn Patrol BMS Series 10 engine at a swap meet. On having a quick look, it appeared to be in reasonable condition and had the few parts I needed to finish off the Gold Cheetah. Asking the owner about it, he says "It's a runner, 25 bucks and it's yours". I offered him $15 and he accepted
A pic of the BMS Series 10 Engine. The outboard version has the tank (much like that of a 102) sitting at the top rear above the cylinder head.
Original carb and throttle, both in great condition.
Ignition cover broken, but repairable. Might even try making a mold to produce a few more of my own.
On the home stretch with the Cheeta now. Just need to repaint the cowl as the initial attempt with wrinkle paint failed miserably .... very uneven finish. I'll post some pics when complete.
