Height Adjustment Collar?
Fenlander
Post by Fenlander »
I'll give this it's own thread as the topic is quite specific.
Am I right in thinking that you can add a clamp/collar to the pivot tube to pull the prop up in the water?
It's just that I've bought a longshaft which is corrct for my aux bracket but it would be good to have the ability to fit the Seagull to my main motor position which is for a short shaft.
Thanks,
David
40 Plus Longshaft 1977 (Serviced & painted) --Silver Century Shortshaft 1977 (Serviced & painted) -- A pile of Silver Century spares.
Vic
Post by Vic »
Well you could at one time but they may not now be available.. They were part no 2/1334C and were called "depth adjusting collar" Mine cost 70p.
However they simply consist of two of the plastic back sections of the "engine support lug" and called "cap for support lug" part no 1334B held together with a couple of studs and four nuts (A couple of bolts and nuts will do)
If you could find a couple of scrap mounting brackets you could rob them of the necessary bits (but that may be deemed a criminal offence amongst Seagullers)
Otherwise make something that will clamp around the drive shaft tube and rest on the support lug
BTW starting a new thread was the correct thing to do.
charlesp
Post by charlesp »
As ever, a call to John on 01621 778859 may well produce a good result.
The very first 'depth adjusting collars' from the 1930 Marston versions are rather nice things in their own right, but the plastic bits described by Vic are every bit as functional.
I have several motors that came with an even cheaper expedient - a jubilee clip tightly screwed to the drive shaft casing...
Vic
Post by Vic »
I decided against suggesting that.. Lets the side down I thought
charlesp
Post by charlesp »
You know, you're right.
Only use a Jubilee clip if you're very desperate.. :D
Fenlander
Post by Fenlander »
Many thanks all. I have just done an order to John for bits and pieces so included a collar as it will be very useful to me.
I agree... jubilee clip in emergencies only if possible!
David
niander
Post by niander »
Sorry but i actually made an adjusting collar out of a mounting bracket using carefully a grinder :roll:
hope not to much of a criminal offence?
charlesp
Post by charlesp »
Well I have to say that I wouldn't actually publicly admit to such a thing, but each to his own.
It's always worth phoning John when short of a bit - there's a huge probability that he can supply one - and reasonably. So much easier then grinding one out of something else.
CatiGull
Post by CatiGull »
Catigull requests a transatlantic translation of 'Jubilee clip' please
Stephen
Awenke Yacht Club
New Baltimore NY
S/V Catigale
Macgregor 26X
Island 17 Sloop
niander
Post by niander »
Its not so bad it was a bit damaged anyways :roll:
there are quite a lot of them things knocking about anyways.....
OK i promise i wont do it again! :shock:
40TPI
Post by 40TPI »
CatiGull wrote:Catigull requests a transatlantic translation of 'Jubilee clip' please
Hose clip as found under hood on older radiator installations.....
Peter
Vic
Post by Vic »
It is a brand of worm drive hose clip. Claimed by the makers to be superior to other brands .
charlesp
Post by charlesp »
Jubilee Clip.
Another great British Innovation. Also used on early 102 petrol tanks instead of the straps. You can still get the (almost) identical product; sadly the markings and nominal sizes are in new fangled foreign metric sizes instead of good old reliable Imperial.
Vic
Jubilee clips
Post by Vic »
I dont know how I missed first time round but see
....................... The Jubilee clip website
TCWest
Post by TCWest »
Hose clamps are nice and all, but I can't see having a jubilee for them. :lol:
"Regard your soldiers as your children, and they will follow you into the deepest valleys.
Look on them as your own beloved sons, and they will stand by you even unto death!"
- Sun Tzu
