Fuel Mix
cobbadog
Fuel Mix
Post by cobbadog »
Hi everyone,
I have a CPCL in my poccession and we are about to use it on a dinghy every now and then. I believe that this engine is to use 10:1 fuel / oil mix. I have only run this engine for a couple of minutes using 25:1 just to test it.
I believe that there is a kit to convert it from 10:1 to being 25:1 is this true?
If so how does it do what it claims and what is in the kit?
Where do I get a kit from here in Australia?
Cheers John
1650bullet
Re: Fuel Mix
Post by 1650bullet »
What year is your motor. You must find that out first before you go swapping needles.
Re: Fuel Mix
See FAQ's on main site.
http://www.saving-old-seagulls.co.uk/faq/faq.htm
Whereabouts in oz are you?
cobbadog
Re: Fuel Mix
Post by cobbadog »
Hi,
Thanks for the replies. Our engine is a November 1963 so it should run 10:1. I intend to do this now using Valvoline TC-W3 2 stroke oil. I also have learnt that SAE 30 is acceptable but impossible to buy here where I live. I tried to get 20 litres of the stuff for a tractor gearbox and couldn't.
We live in Coopernook NSW near Taree and use the Manning and Lansdowne rivers all the time.
segler85
Re: Fuel Mix
Post by segler85 »
If you have problems to get straight-weight gearbox oil like SAE20/ 30/ 90, you can check the engine builders. Many old turning lathes and other maschines need that oil. And Ebay is your friend :wink:
Re: Fuel Mix
Isn't SAE30 old fashioned engine oil?
Re: Fuel Mix
Sae 30 is available from VW specialists, the old air cooled use it believe.
http://www.commaoil.co.uk/productsguide/view/6/260
I mix all my petrol for seagulls 300ml oil to a gallon, approx 16:1, use it for all seagulls early to QB.
I got confused with so many different cans.
Niander101
Re: Fuel Mix
Post by Niander101 »
Good idea :idea:
is still very oilie for a 2stroke
Re: Fuel Mix
cobbadog wrote:Hi,
SAE 30 plain old fashioned like it was is available still.
Castrol 4T, I think it comes in 4 litres?
Failing that, go to a Brigs and Stratton dealer............their branded oil is the same
