Good Guys .
david1230
Re: Good Guys .
Post by david1230 »
BRASS IS KING !!! :D
Silver Century 1971, Evinrude 8hp 1988, Evinrude 2hp 1987
Re: Good Guys .
Not sure I approve of the end result, but I must applaud the quality of your engineering, the prop is a work of art, as is the rope sheave, as a purist I don't like the bronze flywheel but have to admit you've done an excellent job of it.
I hate to say this, but as a "hot rod" it looks very very good!
Re: Good Guys .
How about a grip like this :D Not roo hide, but you get the idea:
http://www.ebay.co.uk/itm/Velo-Tan-Leat ... 20ce1f1711
For HT lead material how about this:
http://www.gsparkplug.com/shop/misc-cor ... n-ybf.html
The great fun in a project like this is you polish it up when you feel like it and tinker with it for ever 8)
Niander101
Re: Good Guys .
Post by Niander101 »
1650bullet wrote:This has been one of the best topics ever. Well done Mate" Definatly something i would never take to water. Its just a bloody masterpiece. 8)
Dont be silly they have to "live" as well as look!
Chilli Dog
Re: Good Guys .
Post by Chilli Dog »
High praise indeed, thank you Charles , I note re your comment that that the original fly wheel and rope pull will sit in a box for ever bonded to this beast .
Oyster , The Ht lead you selected is available here ,a classic car guy resells that stuff , I'll look to obtain some .Not sure about the leather grip . I'd love to up grade to stainless nut and bolts and intend to in the future .I have a throttle lever for it and as you say ,"tinker with it for ever"
Rest assured Niander it will get wet , in the wheelie bin test bed today and in some of or lakes . I'm hoping to go with Tinker down to the Nelson Lakes Antique & Classic Boat Show, & Seagull Outboard Race Lake Rotoiti South. NZ in March and run it there , it would look really good on his british racing green long boat .
Charlesp , i've held a black tank in position and sitting on the black head as it does , it's like the brass tank ,brass exhaust , just a little too much of each in the one area . As i'm happy to grab that steampunk feel , a chromed one especially if I can achieve that tarnished look like Huggies one would be the go I'm thinking . Any way I need to decide which tank to chrome as I only have two and neither one is dent free .It can wait , my be I'll find a more suitable can i date . :lol:
Thanks for your help :wink:
Chilli Dog Racing
skyetoyman
Re: Good Guys .
Post by skyetoyman »
Brilliant job. Glad that you will get it wet. I would use filler on one tank and spray it black then the white and gold tranfer. You can overdo the brass.
Chilli Dog
Re: Good Guys .
I had to make an adjustment to gear bush so I could get it out of gear , but it runs sweet with very little noise. Started first pull
. Little too much suds I'm sorry but dishwashing liquid is a fickle thing (makes the motor so much easier to clean ).
Runs really smooth and at low rpm .The balancing was money well spent . In the test tank it is hard to run motors flat out , 1) unproped they will easily over rev and break something 2) with the prop on they load up on their own wash it looks like the SD prop had plenty of bite and really interested to get it on the boat .
Very happy with how it ran and at this point I consider the flywheel conversion a real success .
Thanks to those that helped @ SOS and Mikes castings , Jan and Graham @ Simply Seagulls. Otahuhu Engineering and of course my seagull mates , you can watch it run via utube at this link http://youtu.be/zcuXEQ05Tl8
Chilli Dog Racing
Re: Good Guys .
Outstanding!
Chilli Dog
Re: Good Guys .
Back to the frustrating job of trying to rebuild sliver centuries today ,they never seem to pump much water ,it's just such a fickle combination .The height of the impeller v's the gasket leaves me wanting to tear what hair out I have left . I have had this motor apart and back together so many times today , every minor adjustment I want to make involves breaking the whole thing down just about and still it looks like it has a bladder problem .
The compression ,the head and the head gaskets , well that's another story and for such a rudimentary timing system I wonder why any body ever thought these motors where worth racing . It's a wonder the bloody things even go at all !!
If any body has a fail safe method to make these pumps run well , I'd love to hear it . ~ I need a cuppa tea .
Chilli Dog Racing
Niander101
Re: Good Guys .
Looking good !
About the silver century..you must have a problem somewhere they normally cool very well
can you blow through the block /pipes easily?
Chilli Dog
Re: Good Guys .
going to remove the exhaust and clamp a hose to the copper feed tube to be sure there is no restriction . With air it 's good , just to be sure .
Sled racing ; ) http://www.jibjab.com/view/8OjV18N_SUaB ... pid=jj_url
Chilli Dog Racing
Chilli Dog
Re: Good Guys .
Water flow is poor and to show you how bad I took a couple of video
http://youtu.be/aDVe07APn3A this is to test for blockage
http://youtu.be/xRPHvy7A7v4 this is the actual flow ( no prop ) and some suds in the water. I guess it would improve with for momentum but I've had them where the stream would be as good as the test .
I'll post a photo of the impeller and gasket soon .
Chilli Dog Racing
1650bullet
Re: Good Guys .
Post by 1650bullet »
Chilli Dog wrote:Water flow is poor and to show you how bad I took a couple of video
Take a pic of the pump housing as well. I wonder if the water tube is sitting in the pump housing snug. :?:
Chilli Dog
Re: Good Guys .
pump housing appears good
Chilli Dog Racing
Chilli Dog
Re: Good Guys .
I will blow air up tube to confirm feeder tube is indeed seated in pump housing
Chilli Dog Racing
