HT Lead Replacing
spiderg
HT Lead Replacing
Post by spiderg »
Can anyone tell me how to replace the HT lead cable,especially into the fitting at the magneto? Is it simply screwed into this sealed unit?
Gerard
Re: HT Lead Replacing
Yes it has a screw inside, it also holds the spring, try not to damage the spring.
spiderg
Post by spiderg »
Thanks Keith, I thought it was screwed but felt safer to check. Being a tight ars.d Scotsman, it would be painful having to buy a replacement part.
Stelios_Rjk
Post by Stelios_Rjk »
Is there availiable that kind of springs? I have one badly corroded and I replace it with one DIY from copper from a wire.
Something like an old style motor brush spring may do the job, if you can find the right size.
spiderg
Post by spiderg »
Maybe John SOS can supply something, he usually gets anything we ask for.
