Concerned about an oil leak.
1650bullet
Post by 1650bullet »
After coming back from a test run yesterday, I took the motor from the trailer to the stand and noticed a heap of gear oil leaking out from the water inlet. Its gearoil. :o :o :shock: :shock: :? :? :!: :!: Does this mean i have a problem????
Chicken
Re: Concerned about an oil leak.
Post by Chicken »
I would say the pinion bush is worn.
33 RACING NZ
1650bullet
Pinion Bush. Ok Thanks Chicken. Another little project for me to do.
Taspiper
Post by Taspiper »
Or the gearbox is overful and the oil is being forced out. I just check my oil every outing and don't wory about any leaks.
Nothing wrong with a bit of agricultural engineering...
Cheers Rolf.
www.acmeengineering.com.au
www.rolfhey.com
1650bullet
Taspiper wrote:Or the gearbox is overful and the oil is being forced out. I just check my oil every outing and don't wory about any leaks.
I think your wright Mate. I took it out on todays river run, And when i brought it home. No oil leaking from it. I checked the oil level. And its spot on. So i must of overfilled it.
Niander101
Post by Niander101 »
dO YOU NOT STAND IT UP AND LET THE EXCESS COME OUT?
OOPS CAPS LOCK ON
1650bullet
I do. But i think what i done was topped it up with oil. And because its so thick it took ages to run out. So i was in a hurry to get going and rushed it threw. Next time i will top it up and leave sit for a while b4 i use it next.
