I think my seagull is extremely noisy, but this my first seagull so I don't really know?
Here's the vid anyway
http://www.youtube.com/watch?v=ADUxf1TBCLY
Noisy Seagull
- skyetoyman
Re: Noisy Seagull
sounds fine ----- just stand a bit farther away from it. I didn't see how deep it was in the water .Having it running at the correct depth makes a big difference to the sound
Re: Noisy Seagull
Sounds very normal.
Re: Noisy Seagull
Ok it sounds the same when its in a river or a bucket and i thought it was very noisy
Cheers Rob.
Cheers Rob.
Re: Noisy Seagull
Sounds ok to me - but if you should want to reduce the exhaust noise, fit water injection and block-off the holes in the exhaust tube, as per the model 102. Then you'll just have the carburettor noise to deal with ...
- Niander101
Re: Noisy Seagull
I did once have a seagull with a shot bigend ...now that was horribly mechanically noisy!
