Given the number it would seem to be one of the later SDs circa 1945-46. There is no ministry stamp on the skeg seen so far. Throttle lever is correct, with a brass tiller. As is the gearbox and prop.
Not sure about the chromed exhaust, driveshaft tube or the flat magneto.
Is there any information re when the flat magneto was introduced, which I thought was on the post war "C" and "D" models? Where any late SDs fitted with flat magnetos?
The engine is soaking with WD40. Good buy at £31.
First job will be to remove and refurbish the tank. First steel one I have had on the bench
