OMG What have I just bought !!!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... SA:GB:1123
Johnson Master twin, can't find anything on the net about it.
Anyone seen one before? Bruce have you got 3 of these :lol:
Re: OMG What have I just bought !!!
That looks like a real project! 8)
You two are going to have to learn how to be selective.
I think that for the british market they were using brass drive tube, exhaust, gearbox. with all the ali it must be worth £40 in scrap :lol:
Worth a punt, when I pick it up and he has a shed full of Marstons I will let you know.
"You two are going to have to learn how to be selective"
Don't worry Charles, H-A and I will leave the easy ones for everybody else :lol: :lol: :lol:
skyetoyman
Post by skyetoyman »
Effingham in Surrey -- shouldn't that town be twinned with Effin in Ireland.
I was in Cork bus station once when a Priest asked where the Effin bus was.
Best of luck with the engine -- that is an Effin task.
I wish I could pick the easy ones, you try getting someone to cut new gears for you, or finding & changing the imperial big end needles & having new pins made for a 5 piece 2 cylinder crank, with having to become a rent grandad.
Another Canadian Johnson, Phil looks like I am going to need your help again :lol:
I has a wicked bronze/ brass gear box.
All I need is a pair of cylinder and a prop, then good to go.
Not sure of the age not mentioned in "The Old Outboard Book" must be early thirties.
What is the chance of getting a pair of cylinder for one of these ? :roll:
P.S. just found it 1934 2.8 HP 8)
What you just got is basically further "Obsession"
Do not listen to detractors.................
Parts, my Mates Doug and Molly (Doing Xmas in Florida next couple of weeks) But......
douglas.penn@gmail.com
Engine numbers and away you can ask.
Thanks Bruce,
I need to find out if the Canadian cylinders are the same as any others.
It is coming apart quite well.
The tank has cleaned up quite well. I have been asked to send pictures of this to a collector in Canada, which I have done.
Just need to get the pistons out of the cylinders.
Cast iron crankcase was a surprise.
Gearbox free, crankshaft bearings good.
The Tinker
Post by The Tinker »
Could you fill us in on how these engines work? Is there two different cavities in the crankcase for each piston? Do both conrods use a common crank pin?
Andy
2 pins 180 degrees apart
common crankcase
self balancing they run very smooth
2 sparks at the same time.
Carb cleaned up well.
Have been speaking to a guy in Canada who has engine 24238, I have 24228.
He only knows of three of these engines, they were built for export.
Mine is the only one that has a tank decal 8)
It was made in 1935 not 1934.
The cylinders may be common with other Johnson engines.
A real find! Keep those photos coming :P
A guy in the states has offered me a parts book for the price of the postage.
There are nice people out there on the interweb.
The cylinder look like they are common with 3 other Johnson types, so looking hopeful.
As Bruce said I need to speak to Douglas Penn, he is the man to find that sort of thing.
Found this advert for the OB 65, export model had bronze gearbox .
http://www.youtube.com/watch?v=AD4WwBAD ... re=related
This is a similar engine that has the same cylinders 8)
P.S. This is of one running http://www.youtube.com/watch?NR=1&v=VGL ... =endscreen Nice and quiet.
