sd 102 restoration. where do I start ?
Re: sd 102 restoration. where do I start ?
That's cheap, they take a lot longer than 95p to make.
I did manage to locate some similar screws but non with a pallister head.
skyetoyman
Post by skyetoyman »
Just started on Amal 2 jet . Jets are marked 02 & 09. Is this correct
The main jet is marked 40, 45 or 50 & I can't remember what the other is, are you reading them upside down?
40 = 25:1
45 = 10:1
50 = 10:1 perhaps cold climate.
skyetoyman
Ooops ...... 50 & 30.
That's made my day :D
John@sos
Post by John@sos »
Best view of one of the new 102 transfers I have seen Terry, nice restoration!
SOS
skyetoyman
Starting to think about putting everything back together. Driveshaft is in really good condition but does it need a finish ?
John@sos
Post by John@sos »
You could paint it Terry or smother it in waterproof grease! Either works!
SOS
skyetoyman
all now going back together again. Much trouble and mess filling gearbox with 140 oil . Eventually removed oil nipple and filled with small pump oil can.
Drive tube giving problems - had to drive out again and scrape some paint off .
cleaned up parts
cleaned up parts
I have fitted new nipples to all the gearboxes I have rebuilt so far. You can then put SAE140 in a cheap new grease gun and jobs a good 'un.
I have some nipples if you want a few. There also plenty on the bay. BSP thread,
Have you come across any black ones?
Cheers....
Avoid the Zinc plated ones, the zinc lasts seconds!
skyetoyman
just read an old post by Oyster 49 that said the thread was 1/4 BSF plus one today that said BSP
Help ?
1/4 BSF
All this talk of nipples is getting my SFs and SPs mixed up.. :oops:
H-A is of course correct as was the earlier post.
