Thanks to UPS, my fuel tank, which looked like this prior to shipping:
now looks like this:
Any suggestions, short of cutting it open, that I can try? Has anyone ever attempted inserting a sturdy bladder (such as one salvaged from a football) and using air pressure to "re-expand" the tank?
I'm tempted to suggest that the very best answer - best as in easiest, quickest, most reliable - is to look for a replacement tank.
Not sure about rubber bladders, but others have had success cutting off the ends and replacing them after a session of precision panel beating. But that seems to be attending to dented end caps, and I don't hold out much hope of getting the central portion back into shape - no matter how carefully you attempt to straighten the flat bits, I reckon they'll still be distorted.
With a 102 tank something might have been achieved, as the central portion is cylindrical, and may respond to internal pressure.
So I'll stick with the first answer, I'm afraid - find another one. I know that may not be as easy as it may sound..
.... or of course, you can refer to the Briish Seagull advertising of the early fifties...
'Fuel tanks, too are a sensible shape and made of brass which can be straightened out or soldered or brazed by any competent ironmonger, garage or blacksmith..' ( My bold)
..so there's another answer.
Obviously the standard of the aforementioned craftsmen has changed over the last half century.
