As a Seagull newbie a few months ago here are some quick notes after 20+ trips out:
- John & John's website here are tremendous resources
- Support from members has been amazing through the Forum
- Selecting correct motor is so easy with a little research here
- Prep & tuning prior to use is important and info is on this site
- My 40 Plus had no spark, but after points and plug cleaned and set all ok
- Prop was sitting too deep in water so collar was added for lift
- Gearbox oil was drained, flushed and replaced.
- Tank & carb flushed and cleaned.
- As mentioned on this site, water may not pump well in tank test (turbulence). Check when on the water. Early.
- Am still experimenting with factory collar, but seems light lube and screw adjustment should provide easy 'rotate'
- Possible failure of orig collar screw(s) could lead to loss of motor over transom so backup connection good idea(?)
- I row out with motor tilted & fuel valves closed, but lowering motor & opening valves - when depth allows - for 1min while rowing means start on 1st pull
- When warm or cold I still start with choke closed, & always starts 1st pull warm. Choke promptly opened after start.
- Expect lots of interest and reminiscences from passerby - I love the guys taking out fizz boats worth $50k-100k who offer tales of their childhood or their Dad etc
- Take out spare fuel but don't mix it. I always take out 1L petrol in plastic container with pourer, and 100ml oil in small bottle. If req'd, mix together in container before adding to tank.
- On return approach, close fuel tap valve. Experience will guide but my 40+ at about 1/3 throttle lasts around 30secs. I then row if necessary.
- All the main tips eg start with throttle fully open are on this site.
- When arriving at your fave fishing spot, wind the cord back on, close the choke, and open the throttle. You're now ready to go again
Thanks again everyone! Have had some great trips out fishing around the islands north of Auckland (NZ) and will have another go tomorrow. Look out big snapper!
Cheers Sam.
