The etiquette on forums seems to be a "Hello" on joining.
I found this site as i'd been "googling" Seagull outboards. I've been after a cheap outboard for sometime for harbour fishing. Portsmouth harbour in my case. Anyway i've been very patient in getting an engine and i've been rewarded.
This is my Forty Minus SJM36691 (Is a minus the same as a featherweight?)
This is my Forty Plus FP959H2
I am told the Forty Minus was a runner once some time ago.... So i took the HT lead of the Plus stuck some oil down the bore and turned it over gently and then gave it a pull. After a couple of pulls i got a spark, i'm confident i'll get that running once i add fuel.
The Plus i'm told he never got it running, now there's a challenge. I'll point out now that both engines have been left with plugs removed in a garden for some time. This engine didn't turn under light hand pressure so i've oiled the bore and will leave it to soak. Any tips appreciated?
The Plus is also missing the carb and HT lead, will any carb and HT lead do?
Andy
