when i first got it the piston was froze in the cylinder and in general it was a mess.
did a complete teardown/rebuild. new rings, gaskets, etc.
grabbing the spark plug wire and rotating the flywheel makes me say "Woo-Hoo" in a fairly loud voice so i know i have some degree of spark.
...and she won't run. most i've got so far is a couple pops and a puff of smoke from the exhaust. just for grims i exchanged the carb with a known good one off another motor. still nuthin'
can't figure what i missed. i never had to pull the points out before, but this one had some corrosion in the points box so i overhauled that too. set the point gap at 0.020". if i have spark could i have anything wrong in the ignition that could still keep the motor from running?
i think this is one of those "can't see the forest for the trees" type of problems...likely the issue is looking right at me - but for the moment i'm baffled.
