That is a real find, Hugz. It's got a whole lot more class than a Folbote. It's a great candidate for an electric trolling motor, since wear from vibration might be more of a problem than a bit of thrust. Will you leave the paint scheme as is? Does it have some sort of significance?
Psychedelic sixties paint scheme! Matches the inside of my sixties van! Charles graciously shared his wisdom with me in adding a longitude thwart attached to the transom and the two existing thwarts. Will give me a more forward seating position as well as strengthening the back. I find the forties vibrate less.
