I have an AMAL 416 carb on my ESC with a fragile plastic air intake/choke shutter assembly which threads onto the carb. Is there any sturdier assembly I can use to replace this?
Also my tank has a plastic fuel tap which does not shut off properly. If it were the metal kind which could be disassembled I could renew the cork washer, but what to do with the plastic one?
AMAL 416 details
