isn't it noisy
Posted: Sat Mar 15, 2008 7:33 pm
i'm very pleased with my new EFPC. it fits my new dinghy a treat, it also means i won't have to cut down my EFPWL which i've become so fond of. After a thorogh tank clean/repaint, new fuel line and gear oil changing exersize it started in half a pull. fantastic! It does seem even noisier than my EFPWL though, which has a cowl over its different type of carb the other difference is that there is a cast tube (almost hidden behind the tank) in the flywheel cover. What is that for? I notice that when they called the various models 'seagull 2' etc. there was a plastic tube looking thing going from the carb to, i suppose this cast tube in the side of flywheel cover. does the flywheel act as a turbo or something? i have also been wondering about the water injected exhaust tube, on some models, does this make them any quieter running?
and could i add this to my motor through on of the existing holes in the exhaut tube to shut it up a bit? im not willing to alter any thing permanently on it but if there was some later noise reducing component i could add, i would. any ideas anyone?
the clutch and anti weed prop make it perfect for the canals and rivers 'round brum.
