102 ignition
Posted: Fri May 05, 2006 10:41 am
I have a Villiers Mark 1 magneto, with the 'nut and bolt' points and the four spoke flywheel.
Thanks to the other Charles I now know where the timing should be set (This one has helpfully omitted the fixed timing feature). But I am having problems with the spark.
When 'whizzed up' with the electric drill the spark is always there; a little weaker than I'd like, but is accompanied by intervals of a very intense bright spark. This bright one you could weld with, and it keeps going for a few revs then disappears.
I've cleaned the points and tried various gaps - I'm aware that these chaps need a smaller gap than later models. I've tried different HT leads, and different plugs with different gaps. The points box is scrupulously clean, and the HT contact on the coil is clean too.
This elusive 'big' spark never goes away completely - I'd love to get the thing set up so it doesn't go away at all.
Any ideas
Any ideas
