				British Seagull 2 models
				Posted: Tue Dec 27, 2022 10:52 am
				by AlainL
				Hello, last week I bought these 2 British Seagulls here in Belgium. Their SN are: SD1389P3 and THCL479D4. They stood in a shed for years. Yesterday I started cleaning up the SD-model. Are there things to pay attention to ? Greeting, Alain.
				Re: British Seagull 2 models
				Posted: Wed Dec 28, 2022 7:37 am
				Welcome aboard Alain.
Well done in getting these as both are very worthy indeed.
First thing is use the search function and importantly...DO NOT use power tools.
Gently gently by hand...
Especially very aged Gulls.
You will be fine.
Keep posting your endeavour aye.
				Posted: Thu Dec 29, 2022 12:35 am
				by andrew
				Look like great motors, good find.
Do you want to get them running again? Or just cleaned up?
				Posted: Thu Dec 29, 2022 8:28 am
				by AlainL
				Hello, THNX for your reactions ! First I will clean them gently and then I hope to get them running again !
Gtz
Alain
				Posted: Fri Dec 30, 2022 10:33 am
				by AlainL
				Hello, after removing the bronze flywheel nut, shouldn’t the flat cover simply come loose ? Here it remains very stuck to the flywheel as if sealed … Many thanks for tips. Gtz, Alain.
				Posted: Fri Dec 30, 2022 2:55 pm
				by andrew
				Yes the stator pulley plate (piece that a rope wraps around) and the flywheel cover plate should come off after removing the main nut. They’re often stuck on with crust on older motors like yours.
Stator pulley plate should come off easily enough and is a sturdy piece. But the flat cover plate below is thin and prone to damage; recommend removing gently.
Some penetrating oil and a few gentle taps around the rim might free it up.
				Posted: Fri Dec 30, 2022 3:37 pm
				by AlainL
				THNX Andrew ! Asap I will give it a try !! Grz.
				Posted: Sat Dec 31, 2022 1:56 pm
				by AlainL
				Hello, it came loose ! JM7101. Gtz, Alain.
				Posted: Tue Feb 21, 2023 12:50 pm
				by AlainL
				Hello
Hereby a picture of the points of my SD Wartime model. Is it correct that the points stay open while turning the flywheel exect for only 1 moment ? Shouldn’t it be just the opposite: always closed and only opening just once and than giving a spark ?
THNX for your reply !
				Posted: Fri Feb 24, 2023 1:08 pm
				The points open to create the spark. The rest of the time they should be closed.
				Posted: Sat Feb 25, 2023 8:45 am
				by AlainL
				That is correct !! How is it possible that mine do opposite ? Is there a solution for it ? What could possibly be wrong…
				Posted: Sat Feb 25, 2023 11:08 am
				If you look at the inside of your flywheel you will see the cam (egg shaped centre) that causes the points to open & close.
If you remove this cover & the spark plug & get somebody to film the points with a mobile phone while you slowly rotate the flywheel by hand you will be able to make a reasonable estimate of how much of a revolution the points stay open!
				Posted: Sun Feb 26, 2023 9:22 am
				by AlainL
				THNX for the tip !
