Spark plug diagnostic / sea trials
Posted: Thu May 07, 2020 1:38 pm
				Finally got to take one of my small gulls out for a sea trial this weekend. 3 minutes in and the tap was leaking fuel and then the prop stops spinning while power head purring smoothly. Hmmm.
Back to the dock for a check and found two surprises. Firstly the fuel cork was not a cork at all, but perhaps some type of decomposed silicone. Like thick jelly, probably decomposed by fuel over the years, I always wonder who makes these sorts of repairs! I had fully stripped this motor last year and I always check the taps, so I must have simply put back on the wrong tap. Easy fix with a new cork but thought the forum may like to see another failed fix.
Next up, the gearbox. Originally I thought the spring had gone, but turns out I had forgotten to install the thrust washer, so the pinion gear was not engaging. Rookie move! Luckily no observed damage to the teeth and also an easy fix, so back in the water it went.
This time it ran amazingly well. No issues for 90 minutes of running. It idles at perhaps the lowest I have ever seen a gull manage, and the full throttle range is smooth. No smoke whatsoever. Water coming out was so cool I felt the cylinder about an hour into running, it was warm to the touch but not hot, which always amazes me. Pushed the family of 4 in a punt effortlessly the whole time.
So onto my question. I’m sure this has been covered plenty, but the search feature is a bit tricky on the forum. Below is a pic of the spark plug, which was a new champion d16 properly gapped and run for about 90 minutes. Can anyone give feedback on the plug condition or point me to a thread that can?
Thanks all!
Thanks all!
