Page 1 of 2
102 help
Posted: Sat Apr 25, 2020 7:31 pm
by lecras806
Hi everyone, I have just started my first 102 restoration. I have done 40's etc but not a 102. I have the power head, fuel tank and exhaust tube. What carb and gearbox/prop went on these? WHCL459R6
Thanks Will
Re: 102 help
Posted: Sat Apr 25, 2020 8:43 pm
by tambikeboy
The 102 used the Amal 2 jet carb exclusively. However, the replacement if it failed, in later years, was the 416, so some may have been changed. Strangely enough that carb will run reasonably happily on 10:1, which older, pre 1968, motors should run on.
Re: 102 help
Posted: Sat Apr 25, 2020 9:23 pm
Search on here for barge pusher gearbox & prop, 13" four bladed cloverleaf & 4:1 gearbox.
Re: 102 help
Posted: Sun Apr 26, 2020 7:32 am
by lecras806
thanks for your quick reply's. will hunt trough the web for the parts i need.
Re: 102 help
Posted: Mon May 18, 2020 8:29 am
by red42hj
Hi, just looking back at 102 help. regarding the prop and gear box; 4:1, does that mean 4 turns of the flywheel to 1 of the prop?
cheers, red.
Re: 102 help
Posted: Mon May 18, 2020 8:44 am
by thcl500j6
Yes
Re: 102 help
Posted: Mon May 18, 2020 8:53 am
by thcl500j6
This is a short shaft barge pusher engine. i have three.
Hope the picture helps.
Re: 102 help
Posted: Wed May 20, 2020 5:42 pm
by roxylass
Beautiful machine I have the long shaft version
Just ordered a new high tension lead for it
Re: 102 help
Posted: Thu Jun 18, 2020 9:08 am
by red42hj
Hi, Just checked my TC102 gear ratio, and it is 5 flywheel turns to 2 prop turns. Do I have the wrong gearbox?
Re: 102 help
Posted: Thu Jun 18, 2020 2:02 pm
by thcl500j6
Post a picture of the gearbox, and we will put you on the right track.
Re: 102 help
Posted: Fri Jun 19, 2020 12:49 pm
by red42hj
Thanks, attached are 2 pics. the engine is TC 55048L 1956 to 66. long shaft clutched
regards. Red.
Re: 102 help
Posted: Fri Jun 19, 2020 3:19 pm
If you check your serial number in the identifier it should tell you all.
TC **** L which is a 102 with a clutch & a 2.5:1 gear box, long shaft & pre 1963.
It would need an H to have a 4:1 lower unit from new.
Re: 102 help
Posted: Fri Jun 19, 2020 10:02 pm
by red42hj
Thanks Charles, it seems the g.box is right for the engine. what would a 4:1 box be used for though?
The reason I queried my box is that the engine gets a bit warmer than it should when made to work hard and then breaks down . I've had to use a smaller prop than normal to get the speed up and get good cooling. But of course the boat speed is down then.
Re: 102 help
Posted: Sat Jun 20, 2020 10:17 am
by thcl500j6
This when its full of crap and people. Or towing other boats back home.
Re: 102 help
Posted: Sat Jun 20, 2020 11:57 am
That would imply your cooling system needs checking from A to Z.
