Fuel pipe ends
Post your wanted adds here
Fuel pipe ends
Hi everyone, does anyone have a contact for a supplier for the brass fuel pipe ends and nuts for the rigid early Marston/SD/early Seagull fuel pipes as they are quite a faf to make and have now run out
Thank you all
Rene
Re: Fuel pipe ends
Re: Fuel pipe ends
Brilliant Adrian, exactly what I was after, I found myself loosing hours on the internet to find a supplier,
Thank you
Re: Fuel pipe ends
Your very welcome Rene! Don't forget the flow bowl end is a 7/16 nut if I recall, so a slightly different ferrule at that end also.
Re: Fuel pipe ends
Yes it’s a bugger, two different ferrules, two different nuts, I used to make then in batches but time seems scares at the moment.
