Crank and Pistons are the same?
Posted: Sun Mar 03, 2019 8:50 am
by african imp
My next Seagull engine build could be a Century or a 102, it depends what parts turn up in the future?
I have a question, the two crank cases I have are both stamped with Silver Century engine numbers.
Would the crank and piston from the 102 series fit the same crank case, as in are they the same?
Re: Crank and Pistons are the same?
Posted: Sun Mar 03, 2019 9:53 am
by fleetingcontact
The pistons are the same although I remember an old thread that asserted new piston rings were too wide for a new piston. Further, some assert that the profiling of the original 102 pistons, a little different to the 'modern' (modern - lol) offering, is more efficient. Its a bit academic though, unless you come across a usable old one.
However, with regard to the crankcases, this is a question I asked quite recently; have a look in the 'Help' section where blokewithaboat gave some helpful info.
Posted: Sun Mar 03, 2019 10:01 am
by african imp
fleetingcontact wrote:The pistons are the same although I remember an old thread that asserted new piston rings were too wide for a new piston. Further, some assert that the profiling of the original 102 pistons, a little different to the 'modern' (modern - lol) offering, is more efficient. Its a bit academic though, unless you come across a usable old one.
Thanks, I will check out the Help section !
