102 tank and fitting
Post your wanted adds here
Wayne1
Post by Wayne1 »
Hi all, has anyone got a 102 tank as I am partway through a resto and nothing on Evilbay for sometime now.........
Fingers crossed that I dont have to use a late one !
Cheers Wayne 07941931827
Re: 102 tank and fitting
Have you contacted John Williams at SOS?
fleetingcontact
Post by fleetingcontact »
I have a steel tank but no bayonet cap so it is unlikely I will use it. The tank was a bit rusty but I've scrubbed it clean and it seems solid. Also have the earlier ally supports.
fleetingcontact wrote:I have a steel tank but no bayonet cap so it is unlikely I will use it. The tank was a bit rusty but I've scrubbed it clean and it seems solid. Also have the earlier ally supports.
Oooh, l'm after one of those if Wayne doesn't require the early steel one. 8)
fleetingcontact
Sold to the Aussie. Arm hanging by a tendon.
persuasive..... 8)
Got to be quick 'round here lol
Then you would need two bayonet caps!
Hugz wrote:Then you would need two bayonet caps!
No, I still only need one for the SD.
I do have one from a Britannia that I can use for the moment. The only external difference is that it is scripted with fuel/oil mix information.
