SJP(L) / FPL Bitsa Journey
Posted: Mon Sep 17, 2018 6:05 am
Picked up these two very crusty, seized engines as a lot a couple months ago (SJP40964L & FPL1348DD4). Needed a fuel tap and line for a project FP, and got these two for about what those bits would cost on their own. So, requisite parts retrieved and the two old birds sitting around = time to start tinkering!
Here is where I am so far with a few pics along the way.
To start, both seized as expected. Let some penetrating oil soak in the chambers for about a week. Then, off with their heads! Bolts on FPL came off fairly easily, with the usual heavy dose of heat. SJP on the other hand, put up a fight. Lower left was a metric bolt rammed in there which came off OK. But those flat-head screws did not want to budge, as slots were already in poor shape from what must have been some heavy torque a long time ago. Gave them an extraordinary amount of heat to no avail, went through 2 heavy duty screwdriver blades and 2 bits on the impact driver before taking a different approach. Had to grind down the tip of the impact driver blade until it was much thicker, just enough to fit in the very top of the screw (I will start with this approach in the future). That was enough to get them out, took about 20 mins each alternating heat/impact driver. The SJP ports were pretty clogged but nowhere near as bad as FPL which had turned into solid rust.
Here is SJP with head off.
And above is the SJP head, probably a common sight for those reading. This raises a question in my mind. What caused the 3 heavily corroded spots? These were behind the gasket which was intact, and exterior of head was in good shape. Was it a leaking head gasket that caused scorching? If so is that predictable/preventable?
Next up, out with the pistons.
My goal is to get a single running bitsa out of them, with as few dollars as possible spent in the process (initial goal was $0 but this has gone up since getting them apart as I will need a new coil at a minimum!). I thought this would be particularly fun/educational project since I’ve never tried to reuse an seized/unseized piston/cylinder before; rather I’ve tinkered out of curiosity and mostly ended up breaking the parts during the inevitable whacking with a heavy hammer. Here is where I am so far with a few pics along the way.
