Seabee ID
Posted: Fri May 11, 2018 8:10 pm
by newfoundland11
Hello to everyone from the US!My name is Craig and I just joined the site!! Hopefully someone can help.I picked up a cool little outboard at the flea market a couple of weeks ago.After looking around on the net a bit ,I thought I had a 34cc Seabee minor.After I pulled the flywheel to clean and set the points(indexed it first),I read on this site that the 34cc doesn't have a keyway.Mine does!Are there different versions of the Minor?On the engine case is stamped S34B/G or 6/76737115.On the case rib next to it is stamped 39.JAP is embossed on the recoil starter.Amal carb.Air cooled.I stripped the carb down,made a couple of gaskets,cleaned the tank and got it to run after only a couple of pulls!I think I'm hooked on vintage British outboards!I've enclosed a couple of pics,Any help would be greatly appreciated.Thanks,Craig
Re: Seabee ID
Posted: Fri May 11, 2018 10:29 pm
Hi Craig
Looks like a Seabee minor to me.
http://www.hofmann.f9.co.uk/history.html
This site has some information.
Re: Seabee ID
Posted: Sat May 12, 2018 5:22 pm
by newfoundland11
Thanks H-A! I'll check out the link you sopplied
Re: Seabee ID
Posted: Fri May 18, 2018 11:47 pm
by newfoundland11
Does anyone know if parts are still available for this? I need a carb cover and a throttle cable! Thanks,Craig
Re: Seabee ID
Posted: Sat May 19, 2018 12:12 am
by Silver Surfer
Engine parts are still available for most of the range of Sea Bee outboards, please contact:-
Mark Newby at
outboard-collector@tesco.net
For new and some second hand parts.
Repair and Restoration services are also available from M.Newby.
Re: Seabee ID
Posted: Thu May 24, 2018 10:16 pm
by newfoundland11
Thanks Silver Surfer,I'll check it out!
Re: Seabee ID
Posted: Fri May 25, 2018 11:36 am
by Silver Surfer
No problem. Hope you get it sorted.
